01 V70 Engine Mounts
I have a couple of questions:
Are the front and rear mounts (#5 in the diagram) hydraulic, and if so, are they a pain to change like the older models where you have to lift the engine up high to get them out?
My second question is, is the passenger side lower engine mount (#1 in the diagram) easy to change? It doesn't look like anything needs to be done to the engine to change it.
Thanks!
Thanks!
Thanks!
Thanks!
Tell me about it. I bought those blue IPD poly bushings and washers for the upper mount bar brackets. I had to cut some of the lining off since they wont fit in the 01 brackets but with that little modification and tightening the bolts to an insane amount, there is a significant increase in stability just with that little adjustment, but the engine vibration also started. It's not that bad though. Most of the time it's barely noticable unless you have a heavy load on the engine.
I do have the OEM Volvo rubber mount, but the newer design one, not the original bad one. I'm leaving it the way it is. If the vibration is as bad as you say, I'd rather not add to it. I do have the stronger front trans IPD torque mount on order. I have a newer OEM one I bought with the car, but I want to beef it up a bit.
I'll let you know what affect, if any, that has on everything. There's just a bit of a new hiccup when going from coasting to accelerating that I'm trying to figure out. I'd rather start with the easy stuff first and try to avoid those hydraulic replacements. I figure just replace the ones I can now and prolong or prevent that hard ones.
Thanks!
Thanks!
I would but it doesn't look like I need to replace anything.
I checked the hydraulic mounts yesterday and they are both fine. I also checked the pass. side mount and that is also in great condition, so it doesn't look like I'll be replacing them.
My IPD performance trans torque mount should be coming sometime next week so once I install that, I'll create a new thread about results.
It referred to something like this:Engine mounting 5CYL 2WD. Fits: 2001 Volvo 2.4l 5 cylinder | VolvoPartsWebstore.com
IPD also had a diagram at one time, also check FCP.
Ed
Ed
