'01 V70 FWD Rear Shocks
How labor-intense are these to change compared to the front? Had anybody done them? I did the fronts on my own a month or two ago, but I think the rears need to be done. I honestly don't feel like doing them myself, but if they aren't too difficult and time consuming, why not. They look fairly easy but some people say they are a pain.
I used a cordless impact to remove the top nuts. Came off easily. Worked great since you can't get in there with a wrench and counterhold. Just remove the floor panel directly behind the 2nd row, move the soundproofing to the side and you'll see the top nuts. Use a T-25 torx to remove the little plastic piece that is in your way. It's simpler than it sounds.
It was an option. You most likely don't have it. The shock is inside the spring. Put the rear on jack stands as high as you can and block the front wheels. Remove the top nut, remove the bottom bolt, and just pass the shock through the control arm out the bottom. Easy job, reassembly is just opposite of that.
Here's a kinda off question; If I buy stiffer rear shocks, like Koni or some other HP ones, will that stiffen up the overall ride, as far as lean while cornerning is concerned, even a bit, or would I need them all the way around? I figure if they are so easy to change and since there are quite a few HP options for shocks, maybe I'll get some nicer ones so I'll have less body sway while cornering, and yes, I do corner that way sometimes at least.
You want a sweet ride in your V70? I've got Eibach Sport springs and Koni shocks/struts. In normal driving it's a tad stiffer, but in cornering it's glued to the pavement. Even if you're not into lowered vehicles, check out the eibachs, they only dropped my height a little over an inch. They advertise 1.2", I'd say mine was less than that slightly.
I used to have my xB lowered and I would have done that but since I got such a good deal on the Sachs front struts I just went stock. I literally just installed them about 1 1/2 months ago so I'm passed the stage where I'm going to spend more to drop it, but I figure I have the chance to at least stiffen it up a bit more with the rears since the Konis and Bilsteins are only a few bucks more then the stock ones.
umbalaxx
05-31-2015 12:32 PM
jared..mann
1998-2000 model year V70
04-20-2013 04:33 PM
parrym
07-13-2007 12:51 PM
