01 V70 Hi-Beams will not stay on
Old Dec 6, 2009 | 07:21 PM
79lilred's Avatar
Question 01 V70 Hi-Beams will not stay on
Just today bought a 2001 V70 and thought I was getting a deal. Now not too sure. Several small bugs to work out but most annoyng at the moment is the hi-beam headlights will not stay on. I read the headlight switch must be rotated over in the 3rd position and not just in daylight running lights mode so have done that. Still, when I pull the turn signal lever toward me, the hi-beams come on, but go back off as soon as I turnt eh lever loose. I do not here a "CLICK" like I'm used to hearing with my other non-Volvo vehicles. Am I doing something wrong or is the hi-beam switch possibly bad and if so, any tips where it's mounted?
thanks!
-steve
Old Dec 6, 2009 | 08:46 PM
byoung2650's Avatar
Default high beams
Greetings,
On the left side of the dash (next to wipers) there is a dial for lights that has 3 positions. In order for the high beams to work the dial must be at 12:00 or the picture of the light.
Hope this helps, good luck!
Old Dec 6, 2009 | 09:24 PM
79lilred's Avatar
much appreciate the reply, but I have already tried that. With headlight switch rotated to 12:00, the high beams act just same as if I still had the switch in daytime running mode.
Old Dec 7, 2009 | 03:50 PM
79lilred's Avatar
took it to local dealership today - they say I need a new "turn signal stalk" for $100 and $70 to install. I think maybe I don't need high beams right now!
nebsch
Mar 11, 2024 05:50 PM
98isb360
Oct 13, 2021 08:47 AM
bkhan145
Mar 16, 2019 02:22 PM
bcolins
2001-2013 model year V70
Nov 22, 2013 09:49 AM
njmotorguy
Dec 8, 2009 03:49 PM
