01 v70 t5 P0172
Old Oct 26, 2011 | 01:22 PM
louie43's Avatar
Default 01 v70 t5 P0172
I have a 01 v70 t5 with 130,000 on the car. Just had the maf go bad, replaced new. Then came front 02 sensor , replaced new. Now the error I get is p0172. I replaced the MAP but still have an the issue. Car runs fine until I put it in park, rpms drop and then come back to normal. If I run errands and start and stop the car through out the day it will not start until I clear the code. I have checked for vacuum leaks and do not see any. Any help would be great! Thanks
Old Oct 26, 2011 | 06:18 PM
Whenever I had that code it was the PCV vacuum line at the TCP valve connection, the small one.
Old Oct 27, 2011 | 08:35 AM
louie43's Avatar
Thanks, I will take a look and see.
Old Oct 27, 2011 | 09:52 AM
Georgeandkira's Avatar
Hello, What does TCP stand for and where is it? thanks, Kira
Old Oct 27, 2011 | 01:08 PM
Can't remember what is stands for, I'll look it up when I get back on my computer (I'm mobile right now). It's at the back end of the intake tube, down stream of the MAF.
Old Oct 27, 2011 | 04:07 PM
My bad, it's called a PTC (had the p in the wrong place). Here is the link to it.
PCV Replacement
grosseile88
2001-2013 model year V70
Mar 11, 2013 07:47 AM
Daviddc114
Mar 26, 2008 06:44 PM
rkent777
Feb 26, 2008 09:38 PM
timothysoconnell
Sep 5, 2006 01:09 AM
JimKW
Jun 6, 2006 09:08 PM
