1998 V70 cooling fan problem
Old 12-28-2010, 07:52 PM
jgerhard45's Avatar
Default 1998 V70 cooling fan problem
I’ve had a problem with my 1998 V70 surging at idle when warm. If I disconnect the IAC it runs fine but idles high. With some troubleshooting it appears the cooling fan is not turning at low speed, it does turn on high speed at about 217F but that’s right where it trips the check engine light. I also have a 1997 850 and the fan turns on low speed at 170F. I have replaced the thermostat and coolant temp sensor. I have swapped a known good relay between cars and the fan still does not turn on at low speed. I have jumpered 12vdc to the fan and it runs fine both low and high speed. Does anyone have an idea why the fan would not turn on at low speed?
Old 01-21-2018, 07:16 AM
Dark Rift's Avatar
Default Coolant temperature
Hello boys,
I own a 2010 volvo d5 awd, recently I borrowed an obd readers and I monitored thst the coolant temperature is not going higher thsn 60 Celsius even after long time running or the car stationery!! Is this a sign of a failed thermostat?
Best regards to all
VancetheVolvo
02-15-2015 08:01 PM
norasaint
09-20-2012 12:53 AM
codynidaho
06-06-2011 10:02 AM
Sebastiaan
05-22-2010 12:49 PM
elouadj
06-25-2008 07:00 PM
Quick Reply: 1998 V70 cooling fan problem
