electric cooling fan problem
Old Jun 3, 2011 | 04:29 PM
codynidaho's Avatar
Default electric cooling fan problem
hey everyone,
So i got a new 850 motor installed into my car after it blew a head gasket, and believe me, i feel like i know that car like the back of my hand now. lol
Anyways, I am kinda having a problem with my cooling system. I have noticed that my cooling fan does not turn on except when i turn my AC switch on and turn my fan switch on. weird? I think so.
So what i have done, is with the ac and fan switch off, i tried bleeding the cooling system and the coolant just kept filling up from the overfill hose. as soon as i shut the car off, it would drain completly.
Now, when i turn on the ac and fan switch, the coolant level remains the same but the fan doesnt turn off. I believe the fan is supposed to turn on only when it needs to regardless if the switches are on or off.
I just installed a new thermostat, coolant reservoir, and made sure there were no leaks.
Any help would be great. Thanks.
Cody
Old Jun 4, 2011 | 10:41 AM
91shelby's Avatar
the radiator Fan is supposed to come on when the A/C switch is on. Did you replace your coolant temp sensor?
Old Jun 5, 2011 | 12:23 PM
codynidaho's Avatar
your talking about the temp sensor that is by the thermostat right? I left the sensor that came with the motor cuz it has less miles than my other sensor. my gauge is working fine, but do you know if there is a seperate sensor for the fan alone?
Old Jun 5, 2011 | 12:30 PM
91shelby's Avatar
Yes that is correct, and there is a relay right above the fan
Old Jun 6, 2011 | 10:02 AM
codynidaho's Avatar
No I have not changed that sensor assuming it works by the gauge. I checked relay and it clicks and works fine. The wire diagram says the hot wire runs to a fusable link? I didn't even know my car had those. I looked anyways and I can't find one anywhere
bcolins
2001-2013 model year V70
Oct 24, 2013 09:13 AM
norasaint
Sep 20, 2012 12:53 AM
troys1992v240
Aug 11, 2012 11:35 AM
la verite 4l
Jun 14, 2008 09:54 AM
la verite 4l
Jun 12, 2008 05:02 PM
