1998 v70, i want 18"R wheels. FIT?
Old Nov 27, 2008 | 12:57 PM
rcsoundn1's Avatar
Default 1998 v70, i want 18"R wheels. FIT?
I have a 98 v70. I found a set of 18"R wheels with tires, will they fit? Claim is they are clean with 5k on them. What are they worth? any help is great. Thanks alot
Old Nov 27, 2008 | 02:21 PM
S70driver's Avatar
Default RE: 1998 v70, i want 18"R wheels. FIT?
Yes they will fit.
Old Nov 27, 2008 | 06:07 PM
TIPSP's Avatar
Got Boost?
Depends on the price.
If you where to go buy them at the dealer it would probably cost $350+ each.
IPD sells pegasus replicas for $178each.
Old Nov 27, 2008 | 08:47 PM
samadkins29's Avatar
they will fit, they will rub with the 215's(tires). If you can get 205's on them than do that.
Old Nov 27, 2008 | 09:00 PM
rcsoundn1's Avatar
thanx, these will be used, i have a friend who is selling a set, tire size is BRIDGESTONE POTENZA RE 750 235-40-R18. when u say rub, do u mean the fronts during a turn as i hit a bump, or all the time? Thanx again for the help!
Old Nov 27, 2008 | 10:22 PM
TIPSP's Avatar
Got Boost?
ORIGINAL: rcsoundn1
They will most likely rub the inner wheel well, that is if they rub. Just get a set of spacers, or some people cut the wheel wells.
Old Nov 27, 2008 | 10:26 PM
rcsoundn1's Avatar
would the rub all the time? I am supposed to go look at them, he is asking $1000 for all four with tires? let me know what ya think?
Old Nov 27, 2008 | 10:34 PM
TIPSP's Avatar
Got Boost?
The inside of the tire will be your problem (Look at the pic where the the struts and springs are is wherthe inside of the wheel well is and where it would rub). The spacers will push it out just a bit depending on how big you go.
Old Nov 27, 2008 | 10:36 PM
TIPSP's Avatar
Got Boost?
See if your friend will let you try them.
A $1000 for real pegs. and tires is a good deal
Old Nov 27, 2008 | 10:38 PM
rcsoundn1's Avatar
he prop will let me try them, and i do want to make sure they are real. Should say Volvo on them somewhere right?
Old Nov 27, 2008 | 10:43 PM
TIPSP's Avatar
Got Boost?
It is kind of hard to tell. I forgot what the back of the wheel looks like. It might say something one the rear of the wheel.
Old Nov 27, 2008 | 10:45 PM
rcsoundn1's Avatar
i was hoping so, usually does for a factory wheel for most manufactures from my experience. He has had them 4-sale for a bit so i may get a better deal. I just hope they fit. Thanx for all you help
Old Nov 27, 2008 | 10:47 PM
TIPSP's Avatar
Got Boost?
They should fit.
Good luck.
Old Nov 27, 2008 | 10:49 PM
rcsoundn1's Avatar
if it falls through and u know someone looking ill keep ya posted and pass the deal on
Old Nov 28, 2008 | 07:22 AM
$1000 is a good deal! Hell replicas are $800 w/o tires. Either way you will need wheel spacers. 235's are wider across than 205's or 215's. By rub I meant that when your at full turn the side of te wheel may rub alittle on the wheel well. Over time the tires will wear down on the inside. But its not a horrible thing, I had 205's on 15's and when i put it back down to 195's boy did my turn radius go up.
ross_theboss
2001-2013 model year V70
May 24, 2013 11:30 AM
98s70t5guy
Apr 1, 2009 06:43 AM
willko1
Jan 28, 2008 03:49 PM
2000v70
Jan 26, 2007 10:25 PM
tcrossley
Jan 24, 2007 10:35 PM
