1998 v70 t5 head gasket blown or something else?
Old Dec 7, 2010 | 07:06 PM
mattg707's Avatar
Default 1998 v70 t5 head gasket blown or something else?
i have a 1998 v70 t5 with 140k. i noticed some water on the bottom of my oil dipstick and i am slowly losing coolant. the car seems to run fine, no smoke and not overheating.
i know usually this means a blown head gasket but im wondering if it could possibly be anything else? i have heard that the oil goes into the radiator is that true? could it be a leak elsewhere? any ideas?
Old Dec 8, 2010 | 10:57 PM
huzzsaba's Avatar
did the low coolant light come on? How do you know you are losing coolant?
I don't know what the temperature is like in your area, but a lot of times when its starts getting cold out, moisture starts to build in the engine causing the water like stuff on the dipstick. Solution is to replace the o-ring at the top of the dipstick.
Old Dec 9, 2010 | 04:39 PM
mattg707's Avatar
i just looked at the car and i do seem to have a drip of coolant on the bottom of the oil pan not sure where its coming from though. It has been very cold here the last few days rarely above freezing. and no lights or warnings have come on at all. there is no frothy white stuff under the oil cap either
Old Dec 9, 2010 | 09:52 PM
huzzsaba's Avatar
I would go ahead and at least change the o-ring to see if it will help.
If not, you probably only spent a few cents.
Old Mar 14, 2011 | 11:40 PM
alonsoal's Avatar
I have S70 with 200k + miles, same problem, noticed some water on the bottom of my oil dipstick and I am slowly losing coolant. the car seems to run fine, However there is white smoke coming out muffler when I accelerate. Also the disptick has some kind of residue, pus-like.
Old Mar 15, 2011 | 12:06 AM
r220's Avatar
Soon you will notice your car is NOT running fine. That gunk on the dip stick - it is clogging your engine. It is the result of what ever coolant is not being blown out your tailpipe running down the cylinder walls and mixing with the oil. 200k miles. Start saving your money for a new car fund.
ladywolf
1998-2000 model year V70
Aug 1, 2015 02:38 AM
shai_kino
Aug 20, 2014 06:45 AM
Reid
Feb 13, 2011 10:01 PM
Rob Gordon
Apr 1, 2010 11:04 PM
buckethead
May 8, 2009 10:13 PM
