1999 V70 Cross Country AWD Cooling fan wont turn on.
Old Mar 15, 2011 | 12:45 AM
rhalve's Avatar
Default 1999 V70 Cross Country AWD Cooling fan wont turn on.
Hi, This is my first time posting..And my first Volvo.
Problem is the cooling fan wont run. I have tested the fan relay by jumping the control wires to ground (yellow and yellow /white). Then the fan switches on and off.
I have replaced the temp sensor and the gauge never goes above half way, but the engine gets so hot I can start to smell antifreeze. I jumper d in a variable resistor so I could trick the ECM to think it was hotter. The Gauge went up and the fan ran. It will run the next time I go for a drive, but not after that. I also noticed that the fuel gauge wont go above half way with a full tank of gas.
I think I have a bad ECM.
Is there a way to calibrate it?
Am I just overlooking something simple?
Any help is appreciated.
Old Sep 9, 2011 | 07:34 AM
ALANJACKSON2011's Avatar
Default Radiator fan
Hello, did you ever get to the bottom of this? For the last year I have had an earth wire running from the relay to my cigar lighter that I plug in every time I start the engine. The 850/V70 and the newer V70 temp gauge is only for decoration. I wrecked my 850 when the rad leaked and the engine got so hot oil leaked and head gasket failed - dash temp gauge stayed normal. I have a 2002 V70 where the fan won't start, the indication that it was hot was NO OIL PRESSURE STOP message and again temp gauge said no problems
Old Dec 14, 2011 | 09:49 PM
rograham1's Avatar
Default Inquiring minds
It was very interesting that you were able to fool the ECM into turning on the fan relay.
Did you ever solve this problem?
I too am suffering from the same issue.
BetterWheels
Mar 20, 2015 01:29 PM
nightojnr
2001-2013 model year XC70
Dec 29, 2014 01:04 PM
kwizman
Oct 19, 2013 05:25 PM
fredrickhewett
Apr 19, 2011 10:03 PM
gibsonplayer45
Apr 27, 2010 12:49 PM
