1999 Volvo
Hello, You don't need a picture of the brake module to remove it. You can see the part with the brake lines in front of and a little lower than the master cylinder. Use an E5 Tork socket-the E stands for external. They're just sockets which fit Torx male heads instead of hex heads. There's an electric plug which needs to be disconnected. Remove the 4 E5 bolts from the bottom of the unit. You can even drive the car with it removed; you just won't have ABS. I'd wrap the remaining part with plastic to keep it clean while driving. Kira
