2001 V70 Fuel Pump Leaking
Old 11-21-2012, 06:07 PM
Mwecker2425's Avatar
[QUOTE=TooManyVolvos;116779]Hi. I am having the same problem with my wifes V70. I tried the epoxy fix and, even though I was metitulous about cleaning/degeasing and roughing up the surface, the smell has returned (though not as bad as before). So, at this point, I am planning to replace the leaking part. Two questions: How do I remove the big plastic ring that holds the whole assembly into the gas tank? What part actually needs to be replaced (the fuel pump itself is inside the leaky plastic housing). Anyone have a part number? Anyone know if Volvo issued a recall to cover the 2001 V70's??? OK, thats 4 questions...[sm=smiley25.gif][/QUOTE
Were you able to replace the pump?'What did you have to do to remove the plastic ring and get the pump out?
  #22
Old 12-07-2012, 09:37 AM
Coleyman's Avatar
Default I had my mechanic pull the entire fuel pump assembly
We pulled the entire fuel pump and replaced it and it still smells like gas but not as strong. So now I am guessing that I have to start replacing hoses
[QUOTE=Mwecker2425;335259]
  #23
Old 12-07-2012, 09:42 AM
CarlaAlvarez's Avatar
Default Gain Muscle Mass With Overall Health Benefits
Along with heavy workouts, if you will take some additional agent to boost your stamina, your muscles will get a fast and easy pump. Nitric Oxide Pills are available for this purpose and are very effective in their tasks with some additional health benefits.
treywils66
2001-2013 model year V70
07-24-2013 02:17 PM
spidersilva
08-17-2011 07:23 PM
bobbie
02-18-2011 06:19 PM
dman777
12-30-2007 03:47 PM
Quick Reply: 2001 V70 Fuel Pump Leaking
