2002 V70 airbox removal
RE: 2002 V70 airbox removal
It is very easy.
Remove the hose to the motor.
Then remove the fresh air hose to the front next to the Radiator.
Unplug the Mass flow sensor and remove the harness from the point on the box.
Some may have the small hose that goes over to the engine and another that goes under the front of the air box. Only the hose going to the motor will need to be removed.
Also if it is a turbo you will need to unhook the Boost control valve from the side of the box.
Then lift straight up on the entire assembly. Sometimes moderate power is needed to pull it out.
Here are some pics I took when I cleaned my PCV.
http://volvospeed.com/vs_forum/index...&album=559
Media
03-13-2010 05:49 AM
