2002 Volvo v70 nonTurbo Cylinder Layout Question
Old Jun 24, 2010 | 08:21 PM
rogue606's Avatar
Default 2002 Volvo v70 nonTurbo Cylinder Layout Question
Hey there, I'm getting an "Cylinder 1 Misfire" code, but am unsure which one of the cylinders is actually number 1. Does anyone have a diagram or picture of this? or could describe it quickly to me visually? thanks in advance.
Old Jun 24, 2010 | 08:27 PM
Cylinder #1 is on the passenger side closest to the timing belt.
Old Jun 24, 2010 | 08:33 PM
rogue606's Avatar
thanks a lot, thats what I thought, best to be sure. If i could bother you further...
I replace all 5 spark-plugs, nothing changed. So after we switched the wires for cylinders 1 and 2, the error code still said cylinder 1 misfire. any ideas on what my issue may be?
Old Jun 24, 2010 | 08:36 PM
Did you swap the coils?
Old Jun 24, 2010 | 08:49 PM
rogue606's Avatar
yep swapped the coils as well, same error code
Old Jun 24, 2010 | 08:50 PM
rogue606's Avatar
could it be that I need a new fuel injector? That's what ive gathered from reading up in the forums so far
Old Jun 24, 2010 | 08:55 PM
Did you clear the code after the coil swap?
Before ruling on the injector I would do a compression test on #1 cylinder.
I have only seen a few injectors go bad. Another way to check the injectors is to pull the fuel rail out some. That is leaving all connected and have someone crank it over and watch the fuel flow out of all the injectors and see if it is the same.
Old Jun 24, 2010 | 09:02 PM
rogue606's Avatar
thanks a lot, I will try that tomorrow morning. Will post the results if you dont mind checking back.
again thanks
Old Jun 24, 2010 | 09:15 PM
I will check back tomorrow night after work.
Chris Kaufman
Aug 12, 2015 11:10 AM
Lv8rmn
May 17, 2014 08:47 PM
mesincity
May 9, 2011 05:40 PM
gabyman97596
Sep 15, 2007 06:43 AM
GaryBrad
Apr 24, 2007 11:48 PM
