2004 V70r fuel issues
Old Dec 23, 2021 | 01:31 PM
AAAOA's Avatar
Default 2004 V70r fuel issues
Hello,
I'm new here and new to volvos and am in need of a little help. My automotive repair background is mostly my little 1984 Mazda Rx-7 GSL-SE and this volvo is a bit different from that. I originally purchased it as a daily as I go through more extensive work on my Rx-7 but the daily volvo has spent more time in the shop than on the road in the few months I've owned it. The most recent problem has to do with fuel.
It has been throwing the p0193 code off and on since I bought it, which I understand to be the fuel pressure sensor possibly being bad. I ignored it for some time as my understanding was it was just a bad sensor, but lately the car has started sputtering under throttle and more importantly blowing the fuel line off the fuel pump and dumping fuel everywhere. The first two times were upon start up in the driveway but I just snapped the line back on and the most recent fuel line failure was on the way home from work which wasn't fun. Initially thinking it was a bad sensor or even a bad fuel pump (even though the fuel pump was replaced less than 20K miles ago), I'm now thinking these issues may be related to the connection between the fuel pump and the hose although I should probably replace the sensor as well for good measure.
Any other ideas as to what may be going on and more specifically how to go about repairing it? I've located a fuel pump assembly and fuel pressure sensor but not the female connection onto the fuel pump assembly.
Thanks guys!
Old Dec 24, 2021 | 03:21 PM
Have you done any measuring of the fuel pressure at the rail? Not sure if this applies to your car or not, but check out Reference Bulletin SMB 23-181, TNN 23-181 which talks to issues with fuel pressure sensors in S60s and V70s. You may want to call a dealer to see if there's anything in play for your car.
https://www.swedespeed.com/threads/p...-input.121174/
Old Dec 27, 2021 | 09:08 PM
AAAOA's Avatar
I have not done any measuring on the rail, but I suppose a bad sensor not reading the correct fuel pressure could cause this problem assuming the fuel pressure in the lines is higher than what's being read which I supposed would then leave the question of why is the fuel pressure so high that it's popping off the fuel pump. I'm going to recover the car now to see what's going on.
Old Dec 28, 2021 | 11:46 AM
I believe your car has the variable pressure fuel pump which uses the sensor's signal to increase or lower the pressure so that would also say to me that if you have a blockage somewhere (could be in the tank as you may/may not have a fuel filter canister on your model) , the computer would sense if the sensors signal goes out of range. Also since you've had work done, you may want to check for any connector/wiring issues going to the pump.
Old Jan 7, 2022 | 08:48 PM
AAAOA's Avatar
So what I ended up doing for the initial problem of the fuel line popping off was bring it to a shop where the hose and connector were replaced. So far, it has remained connected, however P0193 has continued to rear it's head now alongside P0089. Starts up just fine but there is still the odd stutter while driving or under acceleration although not as often as before. Given the immediate line coming off the pump has been replaced there isn't a blockage there although I suppose there could be elsewhere. Next thing in line would be to change the fuel filter followed by the pressure sensor and if that doesn't do it then I'm looking at the fuel pump. The pump was replaced less than 30,000 miles ago so I'm not sure why it would be going out now, but I suppose that's possible.
How would I go about checking the wiring around the fuel pump to insure the wires aren't causing my issues?
Thanks
Suzanne4
Feb 14, 2018 09:21 PM
jonnybuckets
Oct 26, 2011 06:46 PM
fjbrown
Apr 29, 2011 04:58 PM
BarnStorm
Aug 20, 2008 01:21 AM
