98 V70 cam seal replacement
Old May 22, 2008 | 07:18 PM
sporky's Avatar
Default 98 V70 cam seal replacement
Hi...first post! Been working on a recently acquired V70 (base model, no turbo) with 108000 miles. Timing belt was changed at 60K, so I'm leaning towards another belt change soon. Since I'll be in the engine already, I'd like to replace the cam seals. VADIS and Haynes say to use a cam locking tool. I've found other posts for the 850 that say the tool is uncessary, but I'm unsure about my V70. There probably isn't much of a difference between the engines in my 98 and a 97 850, but want to make sure before I potentially hose up the cam placement. Can anyone confirm the necessity of a cam locking tool and ways to work without it (if possible)? What year did VVT for the V70 come out? thanks
Old May 22, 2008 | 07:37 PM
Default RE: 98 V70 cam seal replacement
VVT started late 98.
If you don't have VVT it can be done without locking the cams.
Old May 22, 2008 | 07:49 PM
sporky's Avatar
thanks tech...stupid follow-on...is it blatantly obvious whether or not I've got VVT? Where do I check?
Old May 22, 2008 | 08:09 PM
If you have VVT the front Cam pulley will not be like the other one.
It will be bulkier.
It will also have a T-50 torxes in the center of the pulley.
It will usually be the exhaust cam on turbo models. Intake cam on Non-turbo cars.
Old Jan 21, 2010 | 11:01 PM
flatnb's Avatar
Default How do I set up a VVT cam
I have a 99R that I have replaced the head on and need help setting up the VVT on the exhaust cam. Does anyone have a good write up or pictures on that.
Thanks
Old Apr 6, 2011 | 01:45 PM
capecodbuilder's Avatar
how do you do this? help!! thanks.
Old Apr 7, 2011 | 08:10 AM
flatnb's Avatar
I am not sure what you are asking about. Are you asking about the cam seal replacement or timing belt?
tr_car_nut
Jan 15, 2017 09:33 AM
Jeff Carpenter
Jun 16, 2015 11:45 AM
anniqu
Oct 7, 2012 06:03 PM
thing1
Jan 4, 2012 03:48 PM
Red XC
Dec 3, 2005 12:08 AM
