98 V70 driver door window switch
Old Apr 17, 2012 | 09:29 PM
avarvarigo's Avatar
Default 98 V70 driver door window switch
Hello all.
Quick question. On an 98 V70 driver side window switch. (All four windows), is it hard to replace and does anyone have one that they might want to part with that's good, in the US.
Mine is starting to goof up every so often, primarily on the rear passenger window which works fine with its own switch...
I don't know if they are worth to take apart and try and clean???
Thank you,
Anthony V.
Old Apr 18, 2012 | 12:44 PM
NalleyVolvo's Avatar
Replacement is fairly simple. You need to get a spatula down between the switch and the frame around it. Work gently, because the frame can break if too much pressure is applied. You only need to pry it enough to get the metal clips on the switch to leave the catches in the door panel. Less than 1/4".
After removal, just unplug and swap with the new one. Check all your new switches first before re-seating just in case. There is no software for it like on the newer models, so if you've go the right one it's plug and play.
Ours goes for about $170 online, so don't pay more than that if you go OEM.
Old Apr 19, 2012 | 08:55 AM
avarvarigo's Avatar
thank you very kindly for the reply. i will do my best not to break anything... as to the switch, i'll see if i can get it locally and maybe used though that might be trouble.... i wonder if i took the old one out and try to spray it clean or open it if possible and clean the contacts since it works on and off on that window, if that would help any???
funny that you mentioned software, being old school, i would've never thought of software on the switch... i guess it's a new world...
thank you again. i kept your location in case.
i'm in staten island ny, but you never know....
TV
Old Apr 20, 2012 | 06:07 AM
As long as you know what you're taking apart, and how to put it back together, it can't hurt to take a look at the contacts. I'd use some sort of dry method if I was going to try to clean them.
Yeah, these newer cars can get up past $600 for parts and labor, just for the door switch!
Old Apr 21, 2012 | 05:23 PM
avarvarigo's Avatar
As I said, it's a new world. I wish my old things will last til I die so I want have to deal with the new "plastic" world...
Either way, thank you for your thoughts and I'll give it a try.
Thanks again and stay well.
TV
Old Dec 7, 2013 | 03:57 AM
Richard92's Avatar
what is best way to check drivers side window master switch. My window will not go up.
Can I swap passenger side with driver side plugs?
jetroi
2001-2013 model year V70
Jul 14, 2015 10:54 AM
rspi
1998-2000 model year V70
Mar 1, 2015 01:09 PM
rspi
1998-2000 model year XC70
jeffbyke
May 20, 2013 03:05 PM
Incognito
Feb 13, 2012 03:30 PM
