98 V70 nearly stalls at a stop and a p0171 code
Old Oct 14, 2013 | 01:33 PM
rgreen4's Avatar
Default 98 V70 nearly stalls at a stop and a p0171 code
My 98 V70 T5 233k will almost stall at a stop, idle drops to 500 or less then surges back to normal and will idle and drive fine until the next stop. I've cleaned the trottle body , replaced the MAF with new Bosch unit, spark plugs, wires cap and rotor and replaced the IAC valve with another, I have several used ones on hand. This poblem went away for a while after replacing the MAF but has now started up again. The code p0171 has been a real pia I've checked and or replaced all the visable rubber vaccum line connectors that can find in the engine compartment. Any ideas on where to go next?
Old Oct 19, 2013 | 12:12 AM
gdog's Avatar
Most likely a vacuum leak; have you tried the carb cleaner spray test at idle?
http://engine-codes.com/p0171.html
ToadTheWetSprocket
Jun 24, 2014 08:05 PM
Ethan Morrisson
Engine & Internal
Dec 21, 2012 04:31 AM
eljefino
Aug 6, 2012 11:52 AM
texan_176
May 1, 2011 08:56 PM
