98 V70 Speedo & ECT isssues
Old Sep 10, 2009 | 08:41 AM
Max's Avatar
Max
Default 98 V70 Speedo & ECT isssues
Got a 98 v70 with a speedo not functioning, also shop says ECT sensor faulty. Also Signal lights won't cancel when turning back to straight, maybe just lube issue?
The Thermostat is stuck open, will that affect ECT function?
Shop mentioned different chips for speedo function, what else could be wrong if chips are good? Volvo wants 1800 to replace speedo unit!! Any help appreciated.
Max
Old Sep 10, 2009 | 07:35 PM
Yes the thermostat can throw that code.
Maybe the ABS module is bad causing the speedo to be dead.
Old Sep 10, 2009 | 10:39 PM
Max's Avatar
Max
Default Re v70
Thanks Tech for the reply, would the ABS module give any other indications of faultiness along with the dead speedo?
Old Sep 11, 2009 | 08:13 PM
ABS light on and tracs off light if you have tracs.
91shelby
Feb 15, 2013 03:22 PM
cyonline
Jun 25, 2009 07:47 PM
1996850turbo
Oct 24, 2008 08:53 AM
markisboss
Apr 27, 2008 01:23 AM
