'98V-70XC Vacuum Valve ID
Old Nov 20, 2011 | 12:31 PM
patarack's Avatar
Default '98V-70XC Vacuum Valve ID
I have a damaged Vacuum valve located near steering and firewall. Several hoses attach to it. It must have broken loose from firewall. What is it called so I can order a new one?
Old Nov 21, 2011 | 09:29 PM
Do you have a picture of it? Lots of parts up there.
Old Nov 30, 2011 | 09:35 AM
Franco's Avatar
Default V70 vacuum
Hello RSPI, I repaired it with plastic epoxy. Thanks. I still have the secondary pump problem. Pump works-tested it with jumper leads but it does not have power from fuse box. Fuse tests OK. I changed my user name from patarack (my brothers) to mine-Franco. Do you use email? I am having difficulty on this site..I'll learn I guess. Thanks so much.
jeiiomix
Sep 9, 2014 12:57 PM
autoxray
Aug 24, 2014 02:15 PM
rspi
Oct 12, 2011 06:49 PM
mick1232
May 31, 2009 11:23 AM
mygreenbomb
Feb 29, 2008 06:09 PM
