1997 Volvo 960 - Where is the EGR valve and vacuum control solenoid...
Old Aug 30, 2011 | 08:31 AM
Default 1997 Volvo 960 - Where is the EGR valve and vacuum control solenoid...
I'm trying to figure out where the EGR valve and vacuum control solenoid are located. I think they are causing a P0410 code and I need to try to clean them out to see what happens.
Old Sep 1, 2011 | 08:41 PM
Henry10's Avatar
I think EGR were deleted for 1995 and later 960s. My 98 sure doesn't have EGR.
The P0410 code is for the Secondary Air injection, Bad Air Pump & SAS Valve - PO410 - Secondary Air - Volvospeed Forums
Old Sep 1, 2011 | 09:12 PM
Boy that thread went on forever. I believe I did find all of the componets in the secondary air system. I decided to go to FCP and fish through their parts as if I was going to purchase all of them. The only one I had a hard time finding today was the EGR. It is actually located almost next to the brake fluid res.
I took some car cleaner and sprayed out everything involved and will see if that does the trick.
Old Sep 1, 2011 | 09:39 PM
I think I have properly identified these parts.
Old Sep 2, 2011 | 08:00 AM
Henry10's Avatar
Yes, that looks like EGR. I don't have that.
Air pump and the Valve is easy to take out. I drilled a 1/16" hole at the bottom of the pump, just in case water gets accumulated there.
Old Sep 2, 2011 | 08:25 AM
So, water backing into the pump is the #1 cause of pump failure??? The 960 had a check valve right after the pump. How does water get into the pump?
Old Sep 2, 2011 | 08:31 AM
Henry10's Avatar
When the SAS Valve does not close fully when PAIR (Pulsed Air System) shuts down, exhaust fumes enter the pump. This hot air condensates into water, and many people have found their pumps full of water.
The real question is: did you just get another 960?
Old Sep 2, 2011 | 08:37 AM
No, I wish. I was working on one for a lady.
I'm trying to pick up a S70 today. The lady is down to $500. She overheated the car and now they can't get it started. The top radiator hose was blown. I think it's either flooded or the head gasket is blown. I never took a motor apart like that (head gasket job). I think I'm going to do a compression test on it and decide what I'm going to do with it from there. I think it will have poor/bad compression if they blew the head gasket or messed up something in the motor.
Old Sep 2, 2011 | 09:14 AM
lev's Avatar
lev
Oh yeah, it's probably just "flooded".... Just get the water out if the oil and you'll be ok.
Old Sep 7, 2011 | 08:29 PM
The P0410 code has not come back on the 960. Hurrah!!!
Old Oct 12, 2011 | 01:17 PM
Well the code returned. I'm pretty sure the valve behind the battery is bad. That's next on the list of things to do.
Old Oct 12, 2011 | 02:50 PM
Henry10's Avatar
Maybe the mushroom valve is stuck closed. Take it out -- apply vacuum and you should see it open / blow thru it. Spray some WD40 and it should loosen up.
Solenoid is also a possibility. Solenoid opens up when 12V is applied.
Old Oct 12, 2011 | 03:55 PM
What is the "mushroom valve"?
Old Oct 12, 2011 | 04:13 PM
Henry10's Avatar
SAS Valve. The one that sits on top of the exhaust manifold. Air Pump blows into it.
Old Oct 12, 2011 | 06:49 PM
Oh, could be. I'll try that next time.
matafye
Oct 14, 2012 08:00 PM
VTBricked
Dec 30, 2009 09:11 PM
Erich73
May 19, 2009 11:40 PM
burnferris
Feb 8, 2009 04:43 PM
