99 v70 cat question
99 v70 cat question
Hey my buddy has a 99 v70 with a 2.4l non turbo. It is registered in Arizona but has Cali/fed emissions. I have been told by some that I need a Cali spec cat no matter what. Others have told me that I a non Cali cat will
Keep the engine light off. Let me know what your opinion is
cat code
Hello Hirsch328,
The easy answer to your question is that a 49 state cat can be used in all states other than California. The tough part comes if your local inspection station is really checking out the emissions code on the car. Aftermarket cats have codes on them that indicate complience with California emissions standards. IF you car has California emissions equipment then you would have to replace the cat with a California certified unit to comply with the codes that most states use indicating that "OE emissions equipment must be left intact and in proper working order" in order for the car to comply with any states standards.
Do you happen to know the emissions code number on the car?
Customer Service
eEuroparts.com
Customer Service
eEuroparts.com
