99 v70 engine seized today in orlando,fix or sell the car?
Old Jul 10, 2009 | 12:20 AM
Bruno937's Avatar
Default 99 v70 engine seized today in orlando,fix or sell the car?
Just seized the engine on my V70 non-turbo due to oil pump failure, If I shop around I could get an engine for about $300 and get it installed for about $400. But in the meantime I won't have a car for about two weeks and that's a problem.
What year engines will work on this car? I can fix or sell the car. It's a 99 with a beautiful white body, dark tint, nice wheels, nice leather (except drivers). All in all it's very attractive, looks like a expensive luxury car despite the age. It does however have about 177K miles and now a bad engine. What should I ask for it?
Old Jul 12, 2009 | 08:24 AM
If you can get a $300.00 motor you are really lucky!!
99 and 2000 motors only I believe.
What shop would you have do it?
Old Jul 12, 2009 | 10:49 PM
Bruno937's Avatar
A friend named Rashid will do it. He is a top notch mechanic and was teaching Toyota mechanics. Has a private place on Belle ave in Winter Springs, does mostly dealer repairs and very honest and reasonable. He swapped a S40 engine for me before for $350, worked great. So you dont think a 96 or 98 5cylinder is same as 99-00?
Old Jul 14, 2009 | 07:19 PM
No the motors are different yours should have VVT and the older motors do not.
Old Jul 16, 2009 | 12:27 AM
Bruno937's Avatar
I meant is there any problem using an older 5 cylinder block? Would it not work if we switched the intake manifold and/or other components?
Old Jul 16, 2009 | 08:06 PM
I believe the block only will work you will have to swap the head over.
Old Jul 17, 2009 | 10:20 PM
Bruno937's Avatar
That sounds like too much unnecessary labor. I'll have to find a 99 or 00 I guess. Thank you for the input.
Old Jul 17, 2009 | 10:38 PM
Your welcome.
Old Jul 17, 2009 | 11:00 PM
98T5's Avatar
KEEP IT! $700 is a small investment. you have one of the best models made. I know because I have a 1998.
Old Jul 17, 2009 | 11:01 PM
98T5's Avatar
have it rebuilt.
Old Aug 14, 2009 | 07:14 PM
Volky_one's Avatar
98,99 and 2000 will do. No need to sell.
Old Aug 19, 2009 | 05:21 AM
LPG Karl's Avatar
yes fix the car.
rebuilt from oil pump failure is not viable. will need crank grind, new bearing rings, heads will be (more than likely) stuffed too.
Get a "replacement" motor with PROOVEN history if you can.
Bruno937
2001-2013 model year V70
Nov 12, 2012 10:24 PM
tboysen
Mar 11, 2011 11:17 AM
johnnypaul657
Jun 30, 2010 09:52 AM
mrwenzel
Sep 25, 2009 08:01 AM
GoldGoblin960
Mar 14, 2009 10:24 PM
