'99 V70 Radio
I feel your pain. In general when that happens its either a loose connection or the speaker grounding out (short). Best bet would be to open up the door panel andinspect the speaker and wiresfor any visible problem. Check the connector andcheck for clearance (make sure nothing else is touching the speaker causing a short). If it all checks out the problem may be at the amplifier. Do the same and check for issues.
rspi
04-12-2013 04:21 PM
850keeterbeata
09-25-2009 04:33 PM
