99 V70 Tbelt removal
Old Jan 21, 2008 | 08:24 PM
aalvear's Avatar
Default 99 V70 Tbelt removal
Newbie. I have 2 questions on V70 std 100K miles. I have followed VADIS up to ....
1. I have a mechanical tensioner. Do I have to replace it? Not sure from VADIS
2. How do the heck your remove the belt? VADIS tells me to remove vibration damper (30 MM big mama socket) with a special VOLVO tool # 999 5433 (to hold the other 4 nuts). Way down by the plastic hatch on the RH wheel well.
Is there any WAY to remove the belt w/o doing that. Do not have the special volvo tool
I think tech said to remove the metal shield behind it but all I see it is the Tbelt plastic cover at the bottom of the crankshaft. Do I remove that? If so, what do I need?
BTW, this is my 2nd 99 V70. Love these machines.
Help is very much appreciated. Best regards
Old Jan 21, 2008 | 08:49 PM
Default RE: 99 V70 Tbelt removal
You can try I always remove the lower crank pulley with air tools it is a breeze.
I would replace the tensioner and idler pulley because the life span of them is only 80,000.
Old Jan 21, 2008 | 09:01 PM
aalvear's Avatar
I will replace tensioner and pulley, however, I do not have air tools neither special volvo tools.
So what do next?
Remove the 30 mm BIg bolt and then the other (4) 10mm?
Thanks
Old Jan 22, 2008 | 06:11 PM
If you can get the nut off that will be great.
Then the 4 10MM screws.
Then take a hard rubber mallet or the rubber insolated deadblow hammer and hit the pulley a couple of times and it should fall off.
Old Jan 22, 2008 | 06:38 PM
aalvear's Avatar
I ordered the tensioner and the pulley, but I do not think I can get the old belt out w/o proper volvo tool, P/N 999 5433.
You can buy it, I will confirm tomorrow, at Kent-Moore Tools in Minnesota. 1-800-345-3399 for ~$45
Thanks
Old Jan 22, 2008 | 06:55 PM
Do you have a picture of it?
I don't use any special tools at all.
Old Jan 22, 2008 | 08:01 PM
aalvear's Avatar
Here there are the pics. One is the crankshaft and the othwer the not-so-famous tool
I guess you need the tool otherwise I would lose the timing.
[IMG]local://upfiles/9254/87FC83EF4CA44C93848A88049BB7FF6E.jpg[/IMG]
[IMG]local://upfiles/9254/1C225B343AC046698C07A91FE9880325.jpg[/IMG]
Old Jan 22, 2008 | 08:22 PM
That tool screws outside the pulley to help hold the crank for you to loosen the 32MM nut.
But for the cost of the tool I would buy an electric impact for the job or find someone with Air tools to break it loose for you.
Old Jan 22, 2008 | 08:51 PM
aalvear's Avatar
Don't I have to hold the (4) 10mm screws in place if I use an electric impact wrench? Thank you
Old Jan 22, 2008 | 09:55 PM
If you use the electric impact you won't need to hold anything. It really won't spind. The impact is like a hammer trying to loosen the nut but really fast.
960 Wagon 95
Jan 26, 2011 07:00 PM
volvoQ's
Nov 18, 2010 09:11 PM
liamhenryf
Jun 20, 2009 07:58 AM
sadlers
Apr 1, 2007 10:34 PM
svendyensen
Jun 29, 2006 08:32 PM
