99 V70 Window regulator removal
Old Apr 1, 2007 | 10:34 PM
sadlers's Avatar
Default 99 V70 Window regulator removal
I need to replace my rear passenger side window regulator and have run into a few problems.
I have checked power to the motor and everything is good. When the switch is pressed I can here a faint thud but the window does not move. If I hold the button long enough the fuse will blow and I have to reset the ignition to get it back. Im assuming the motor is bad or the regulator is bound up.
I have removed the panel removed all connections and bolts holding the regulator. I need to know what to do to get the regulator out. How is the window attached to the regulator ? I am unable to pull the window up manualy if that meens anything.
Veronica Tumavicus
Nov 1, 2017 07:08 AM
reecesp1eces
Feb 2, 2014 08:44 PM
bcolins
2001-2013 model year V70
Nov 11, 2013 03:56 PM
aeabston
Oct 29, 2006 11:10 PM
xoneinax
Sep 14, 2006 10:28 PM
