ABS, CEL, BRAKE etc... HELPPPP!!!!!
Old Jun 12, 2007 | 01:27 PM
Volvo V70R's Avatar
Default ABS, CEL, BRAKE etc... HELPPPP!!!!!
The ABS, CHeck Engine AND Brake warning lights come on when the engine, on it's own, changes RPM's. Then - the speedometer goes to 0 mph and the two milage readings, odometer's, go to dashes. It can stay that way for a while, then go back to all lights go off except Check Engine.
Yesterday the lights came on AND the orange arrow representing "W" mode came on blinking and the car went into that W transmision mode, slower, more set for winter, slippery driving.
The speedometer abd odometer readings go off now 8 seconds after the Brake, ABS, "W" orange arrow and check engine light comes on. Seems like it's all getting worse.
I went to AutoZone for the OBD II tester gave 4 errors related to the Output Sensor curcuit, Main Catalys belwo threshold Bank1, Mfg controlled vehicle speed idle control, Mfg controlled computer and aux outputs.
Old Jun 12, 2007 | 06:00 PM
Default RE: ABS, CEL, BRAKE etc... HELPPPP!!!!!
The ABS module is bad.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
Old Jun 12, 2007 | 06:50 PM
Volvo V70R's Avatar
NIce, I was just making sure that was all that was wrong. THanx again man
Old Jun 12, 2007 | 07:08 PM
Volvo V70R's Avatar
All of those can be attributed to the ABS module?
Old Jun 12, 2007 | 09:10 PM
The only one that may not be affected is the Cat Converter code.
But then again it might.
These cars get screwy when the ABS module goes bad.
I have seen an ABS module totally shut a car down when it went bad.
jojoswhip
Feb 16, 2015 01:48 PM
VOLVORRD
Sep 30, 2014 11:02 PM
cheebster
May 8, 2014 04:31 PM
matt01
Jul 23, 2012 11:12 AM
zloetakoe
May 28, 2011 07:29 PM
