Accel.Pedal Sensor....yikes, not ETM
Old Jul 22, 2009 | 12:57 PM
unamaste's Avatar
Default Accel.Pedal Sensor....yikes, not ETM
Dealer pulled codes after the "Urgent" service warning. Only numbers on invoice under "tech" is 924 which is probably not a code. 01' V70 with 128K. the part they recommend is #30683516 ($152). Should I try to replace or let the dealer do it? I'm thinking it might simply be the ETM that needs replacing. Any insight much appreciated and thank you!
Old Jul 22, 2009 | 07:10 PM
That might be the pedal sensor if it is then you should be able to handle replacing it.
radio16
Jan 18, 2010 02:59 AM
unamaste
Jul 22, 2009 12:59 PM
rah689
Mar 30, 2008 09:47 PM
gridlockfilms
Nov 26, 2007 11:49 PM
gridlockfilms
Nov 26, 2007 07:22 PM
