After Market Half Shafts
Old Sep 24, 2010 | 09:30 PM
checksix's Avatar
Default After Market Half Shafts
Went to the stealer today to schedule the fuel pump recall service (01 V70 T5a). While I was there I asked the price on the half shafts as I have a very slight noise on my driver side that only presents itself when turning hard left and there is a slight bump. They quoted About $500 a side which I thought was NUTS. What's the current forum recommendation on where to purchase quality replacements?
Jerry
Old Sep 25, 2010 | 06:13 AM
Have you tried to lube the steering stops yet?
The aftermarket ones are so so. I have installed some that vibrated right away after installing them.
Old Sep 25, 2010 | 11:16 PM
checksix's Avatar
Tech, thank you for the reply. I thought the stops were fixed and have never heard of applying a lub. Can you please elaborate as to where, how and what is the perfered lub?
Jerry
Old Sep 26, 2010 | 07:04 AM
Any mind of grease or anti seize. You can put it on the plastic pieces on the control arm or the curved metal part on the hub itself.
Old Sep 26, 2010 | 09:59 PM
checksix's Avatar
Worth trying for sure. I am wondering if I've ever hit the stops as my tires rub (since new, and 3rd set of tires), so I back off when I hear that noise and probably never hit the stops. Can you adjust the stops to prevent this?
Jerry
Old Sep 27, 2010 | 08:35 PM
You can put a few washers between the stops and control arms to move the stop out. That should also stop the tires from rubbing as well.
pinky
Jul 12, 2013 10:56 AM
Annihilator
May 19, 2011 05:56 PM
checksix
Nov 13, 2010 06:38 PM
tr_car_nut
Aug 3, 2010 10:04 AM
checksix
Jan 22, 2010 08:49 PM
