Air Pump Woes
Okay, I managed to replace the SAS valve. Now I'm working on the air pump itself. The old one I removed was waterlogged (as expected). I got a used one on eBay and installed it just now. Before I attached the electrical connections I hooked up my circuit tester instead. Then I pulled out the relay and jumped it to make sure that I was getting 12V to the air pump, and sure enough, I am getting 12V at the connector. Then I plugged in the air pump, jumped the relay again, and NOTHING!! ARGH!!! What did I do wrong?
Okay, I removed the air pump and tested it again by connecting it directly to the battery. This time, I noticed that about 5-7 seconds after I make the connection, I hear a tiny little click coming inside the air pump that sounds like a relay. Then I hear it again when I disconnect the battery. I'm not hurting anything by hooking it directly to the battery, am I? What might that click be?
