Another vibration issue
Old Apr 29, 2006 | 03:40 AM
Volv oohh's Avatar
Default Another vibration issue
01 V70 T5. It had some front end vibration so I took it to the dealership (yeah, I know) They replaced the engine mounts and did an alignment. The vibration has returned and is now worse. On top of that, there is a low, dull "rattle" when I drive on rough pavement or drive over even small bumps in the road. WHen I drive over speed bumps I hear a "pssst" on the left front side. Does it sound like the suspension? I've read the many comments on the "truck like" ride of the V70, so I don't really know how much is too much, but it's definately harsher than any other car I have owned.
Just curious, if I were to replace the suspension (struts/shocks) to factory level parts, what can I expect that to cost? BTW, this would not be a DIY job for me.
Thanks in advance.
Old Apr 29, 2006 | 11:20 AM
Default RE: Another vibration issue
You could have many problems.
One of the tires might have thrown a wheel weight. (Vibration)
The Rattle could be either a bad spring seat or a bad swaybar link.
The factory struts are pretty expensive. I think like $300.00 each for the struts. The rears should be a little cheaper. Labor like 3 hours for the front and about the same for the rear.
Caberguy
Jun 25, 2014 12:15 AM
donf
Jul 4, 2012 08:47 PM
96960Chris
Jun 25, 2011 04:49 PM
ocean238
Apr 17, 2008 06:20 PM
Meglog
Aug 17, 2006 09:17 PM
