which automatic transmission???
Old Sep 22, 2008 | 05:36 PM
hordezla's Avatar
Default which automatic transmission???
My '01 v70 needs new tranny. I am looking to buy one from car-part.com andI see that for this particular year they have more than one transmission. Even if I selectmodel that has same options as mine (FWD, AT, 2.4T, no geartronic) it still comes back with 3 different trannies. What number is the most important one to match?
There is "N" number, is that actual tranny number or just serial? From what I understand difference is in number of connectors or their shape? Tech, any idea?
thanks!
Old Sep 23, 2008 | 06:52 PM
Default RE: which automatic transmission???
AW 55-50SN is the type of number you will look for on the top of the transmission.
Old Sep 24, 2008 | 07:01 PM
hordezla's Avatar
thanks tech!
It's too late, they sent me one with 4 connectors and mine has only one. I guess they sent metranny from S60 that supposely fits some 70 models? Good thing they will take it back.
Everyone else that I called today also has one with 3 or 4 connectors. Do you know if transmissionswith one connectorare rare? With my luck it probably they probably are[:@]
Old Sep 24, 2008 | 07:16 PM
On the 01's yes they are rare. But if all the numbers match up then worse case you can swap the harness from your old one to the new tranny.
We have done this many times before without any problems.
Old Sep 26, 2008 | 02:17 AM
rules's Avatar
Hi
Sorry for jumping in the middle here, but what's the odds of an R 6 speed gearbox fitting in my car?
Cheers.
Old Sep 26, 2008 | 07:47 AM
hordezla's Avatar
ORIGINAL: tech
tech, sorry to bother you again but if you could answer this one I'll appreciate it. I am looking at plate with 55-50SN number andnext to itthere are 2 numbers; one is 9482025 and the other 00cv712497. Which one needs to match? thanks again
Old Sep 26, 2008 | 07:37 PM
You need a 55-50 transmission. The 9482025 is the Volvo Part number. I think the 00cv712497 is the serial number.
Old Sep 26, 2008 | 07:38 PM
ORIGINAL: rules
Hi
Cheers.
It might fit but not sure never tried.
Old Sep 26, 2008 | 09:35 PM
hordezla's Avatar
Tech, thanks for your help, great as always.
Old Sep 26, 2008 | 09:43 PM
Your welcome anytime.
Old Sep 27, 2008 | 01:44 AM
rules's Avatar
Actually read on another forum that physically doing a auto manual swop is not such a problem. The problem comes in with the electronics (as per usual).
Old Dec 19, 2011 | 09:29 PM
volvoseek's Avatar
Same sort of question here, wonder if you can chime in Tech?
I've got a V70 T5, transmission 55-50 part number 9482025.
Found a used one, also 55-50, but the part number's 8636081.
Is that going to fit or must my quest continue?
Thanks
mathieu_p
Jan 19, 2013 02:06 PM
schoolloans
Jun 18, 2009 08:34 PM
ko_kidd
Aug 25, 2006 08:53 PM
pgup
Jun 27, 2005 08:47 PM
94volvo850
Feb 18, 2005 06:49 PM
