blower motor
Old Jan 11, 2008 | 10:08 PM
joshuab's Avatar
Default blower motor
I read alot of the posts on here and had a question (or 2) about the blower motor. I have a 98 V70 Turbo and there is no airflow from the vents. If I switch the settings from feet to dash etc I hear what sounds to be the system setting the air to flow from the proper ventsbut still no air. At startup I get the blinking lights. I can go to autozone to pull the codes but I was wondering if it's already a 99% chance that it's my blower motor and I should just go get a new one. I'm in a hurry as this is my wifes car, I live in Chicago and it is damn cold. If I don't fix this quickly she'll take it to the stealership.
Laslty how do I access the blower motor?
Thanks in advance
Old Jan 11, 2008 | 10:17 PM
Default RE: blower motor
1. Replace the blower motor and resistor. (Auto Zone usually can't read climate codes)
2.Remove the glove box insert then the lower dash panel. Remove the black metal bracket 3 13mm screws. Then you can see the blower motor and easily access it.
Old Jan 12, 2008 | 09:32 AM
joshuab's Avatar
thnk you much. One last question I was going to order the parts through FCP Groton however they don't discern if you have a manual or electronic climate control. Does that matter for the motor and resistor? I'd hate to order them only to find out they sent me the parts for a manual when I have an electronic.
Thanks.
Old Jan 12, 2008 | 09:39 AM
The motor will be tthe same no matter what.
According to the link ECC is different than MCC here is a link to one with ECC.
http://www2.swedishpartswholesale.co...r&dp=false
Old Jan 12, 2008 | 01:49 PM
Pretorien's Avatar
Just followed that link out of curiosity - unless the "blower resistor" is a wire wound platinum item with solid gold binding tabsl, the price is absurd!
Pretorien
Old Jan 12, 2008 | 05:34 PM
Yes they are expensive but you most likely will keep burning up motors or loose everything all together without it.
jmallie
Sep 17, 2009 09:47 AM
florida98s70glt
Sep 11, 2009 07:56 PM
etype38
Dec 27, 2005 02:17 AM
wojeepster
Sep 30, 2005 09:13 PM
woodworker
Aug 24, 2005 09:06 PM
