can change alternator but the belt another story
Old May 27, 2010 | 11:40 AM
pondo's Avatar
Default can change alternator but the belt another story
Just finished replacing my alternator. Everything went pretty well. For the life of me i can't put my serpentine back on. Is there something I'm missing. The tension pulley pulled to its max. Maybe i just don't know what pulley to do last, or will it help if i loosen a few bolts on the power steering to give me a little play. Any advice would be greatly appreciated.
Old May 27, 2010 | 12:16 PM
SVTfocusO3's Avatar
Make sure you put it on the way it came off, do you have it looped around right? Is it not fully on a pulley, say the a/c? Should not be to difficult.
Old May 28, 2010 | 11:21 PM
checksix's Avatar
I'll bet money you have if routed wrong. Check the diagram real careful!
Jerry
Old May 29, 2010 | 07:08 AM
SVTfocusO3's Avatar
These cars have no diagrams unfortunately.
Old Jun 3, 2010 | 06:44 PM
klkst's Avatar
Check this site out they had a diagram of how the belt goes for my car just look up the belt for your car.
http://www.eeuroparts.com/Main/Home.aspx?home=true
Old Jun 3, 2010 | 06:46 PM
klkst's Avatar
this help
Old Jun 8, 2010 | 01:24 AM
Ferbis1021's Avatar
I just had an idler break on me last Thursday! $80 later, the idler was reinstalled.... but I played hell getting the belt back on as well. My suggestion is to take the two 14mm(?) bolts out, put the tensioner in a vise (or hold it somehow) and put it all the way to the max position and put a lock pin through the hole, reinstall the tensioner with one bolt loosely so it can pivot, then get the belt ran and reinstall the other bolt and tighten. *shrugs* Worked for me.
Linkesh Diwan
Jun 13, 2015 06:03 AM
wojeepster
Jan 6, 2007 11:58 AM
aquamanz
Aug 25, 2006 11:50 AM
Buck
Jul 27, 2006 07:16 PM
v70 2.4t
Jun 11, 2006 07:21 PM
