CBV Replacement
Old Jun 8, 2009 | 03:02 PM
FirstV70Volvo's Avatar
Default CBV Replacement
Photos and a write-up for replacing the compressor bypass valve diaphragm and spring. Something I recently did as I took things apart to check my turbo for boost problems. Like I mention in the write-up, I am not sure how often the CBV diaphragm or spring goes bad (Tech???) and I don't know if it's necessary to replace them as preventive type maintenance but if you plan on doing this job I hope this helps out.
http://www.box.net/shared/zdjf64r3k3
Old Jun 8, 2009 | 07:20 PM
I have not had to replace any of them as of yet. Thanks for the info.
I will pin the topic.
Old Jul 14, 2009 | 07:39 AM
HummerGuy's Avatar
Thanks for posting the info FirstV70Volvo!
Old Oct 19, 2009 | 12:54 AM
lovely09's Avatar
A method for bypassing excessively compressed intake air in a turbo-charged engine system comprising determining, by a throttle valve position sensor that a throttle valve has been suddenly closed wherein said determining is performed by analyzing a value of time derivatives of an electric signal (voltage) generated from the throttle valve position sensor and bypassing excessively compressed intake air from an intake manifold to a air intake before said compressed intake air reaches a compressor of a turbo-charged engine system.
Old Oct 19, 2009 | 06:32 AM
Prof's Avatar
Say what? Please.
Old Dec 9, 2009 | 09:22 PM
kurtdaniel's Avatar
yeah,,it helped out a lot..tnx..please also post a diy for volant cold air intake installation..coz ive lost its manual..
Old Jan 21, 2010 | 12:47 AM
nstescolias's Avatar
I found this sitting on my parts shelf and don't need it anymore. It is the Viva Performance "CBV upgrade kit" that I bought directly from Viva for my 850 but their website lists it should work on any turbo in the TD04 family. Please check your fitment before buying. It is new, never installed. Took it out of the box to look at it and that was it, went right back into the box.
Asking $45 shipped within the United States. I accept Paypal, please e-mail me with any questions, thanks.
Old Jun 11, 2010 | 10:11 PM
C70's Avatar
C70
Just replaced my factory cbv last month with heavy duty one from ipd.The factory cbv (covered in a little oil) looked brand new but i replaced it and the rubber hose anyway for peace of mind.
Old Mar 7, 2012 | 11:14 PM
Captainkirks60's Avatar
I have a similar question.... To install a bypass valve it's a turbo xs bypass valve do I just replace that stock cbv with it ? Does anything need to be blocked ? I just need some install guidance not sure if I'm on the right thread for this I just joined sorry if I'm not
B00$T CR33P
Apr 29, 2010 10:45 AM
matt01
Mar 27, 2010 01:09 AM
yert315
Sep 21, 2007 05:04 PM
Catchincotton
Oct 24, 2006 05:59 PM
S70driver
May 7, 2006 05:46 PM
