Climate control knob stuck
Old Apr 9, 2008 | 04:19 PM
tanjung66's Avatar
Default Climate control **** stuck
Climate control **** on the driver side of my V70 got stuck. What should I do? Do I need to remove the control unit? If so how?
Thanks
SS
Old Apr 9, 2008 | 05:47 PM
Default RE: Climate control **** stuck
Do you have ECC or MCC?
Old Apr 9, 2008 | 09:19 PM
tanjung66's Avatar
MCC.
Old Apr 10, 2008 | 12:57 PM
tanjung66's Avatar
Tech,
I found out what is wrong with the ****. The geared plastic arm where the **** mounts is broken. Is there possibility to replace this little plastic thingie?
Where can I find the climate control assembly (not the display part)?
Thanks
SS
Old Apr 12, 2008 | 07:51 AM
Try finding a used one from a junkyard.
These are becoming pretty common to go bad.
Sorry so long to reply been sick.
Old Apr 13, 2008 | 08:01 AM
tanjung66's Avatar
Thanks Tech.
I called the Volvo dealer in O'Fallon, MO and got the OEM part number for the Control and I am going to buy it from TheVolvoPartsClub.com.
Anyway, the OEM part # is 3524842
Old Apr 13, 2008 | 09:00 AM
Glad you found one.
Old Sep 9, 2014 | 09:45 AM
otaranda's Avatar
I own 2007 XC70 and ECC AUTO/fan control **** stuck in pressed state. It suppose to turn auto mode on and off by pressing on that ****. Now I can regulate fan speed but cannot press it toenable automatic control.
Any advice? Can I pray and remove **** or anything more valuable? Thanks .
mhphoto
Apr 27, 2011 06:55 PM
VolvoCarl
Dec 15, 2009 07:06 PM
jonnyboyca
Mar 7, 2008 01:42 PM
jonnyboyca
Feb 21, 2008 12:27 AM
jfikentscher
May 31, 2006 09:58 PM
