Coolent Smell
RE: Coolent Smell
Hi je
I recently had a problem with the coolant pipes , that connect to the heater core, leaking on my V70 and it was "relatively" easy to fix (just had to replace two rubber o-rings).
I could access my heater core by removing the centre console lower side cover (turn the "plastic screw" 90 degrees and slide the whole panel rearwards). I eventually ended up removing the glove box as well just to make it a bit easier, but my car is a RHD so yours might be on the driver's side.
Here are some pics ...
http://volvospeed.com/vs_forum/index...&album=513
Hope this helps a bit.
cmanns
01-01-2010 06:51 PM
colgate41
06-28-2007 07:57 PM
