cooling fan control
Old Mar 18, 2012 | 05:07 PM
kenpack1's Avatar
Default cooling fan control
I have completed a timing belt replacement kit install on my 01 V-70 project. I fired it up yesterday and noticed the radiator cooling fan does not turn on when i run the A/C. Also i have a 'low coolant' 'turn engine off' displayed on the onboard message center. (I guess thats what it is called). Is this a faulty ETC that is below the themostat housing? I have plenty of anti freeze and heat from the heat vents. Any help please?
Old Mar 30, 2012 | 06:49 AM
If neither of those problems existed prior to you doing the timing belt, maybe you left something off. Usually the AC will not work with the fan off???
norasaint
Sep 20, 2012 12:53 AM
red7218
May 3, 2012 01:03 PM
red7218
May 3, 2012 12:55 PM
elouadj
Jun 25, 2008 07:00 PM
Carbuff
May 26, 2005 12:01 AM
