Crankshaft Timing Mark
Old Sep 15, 2008 | 10:15 PM
  #21
Default RE: Crankshaft Timing Mark
Usually if you give it a decent tap with a hammer it will just fall off.
Old Sep 16, 2008 | 02:36 PM
  #22
Rascal2pt0's Avatar
mine had 4 bolts holding it on in addition to the main one.
Old Sep 21, 2008 | 04:18 PM
  #23
sporky's Avatar
I ordered the volvo special tool for the job...still waiting for it to come. Didn't want to fork out the cash for an air compressor, wrench, and sockets for this one job. Couldn't find anyone that rented a gun either. Tool was about $50...hopefully can make some money back on it if I should ever sell it on ebay.
Old Sep 21, 2008 | 05:36 PM
  #24
Which tool did you buy?
Old Sep 21, 2008 | 07:59 PM
  #25
sporky's Avatar
the counterhold 999 5433. got it from http://www.spxvtc.com/
Old Sep 21, 2008 | 08:11 PM
  #26
That should work.
Old Sep 23, 2008 | 06:50 PM
  #27
sporky's Avatar
It worked great! That puppy was on tight! Needed a 1/2" breaker with extension to pop loose. No way could an average impact wrench loosen it.
Old Sep 23, 2008 | 07:49 PM
  #28
Glad it came loose.
Old Sep 25, 2008 | 04:05 AM
  #29
rules's Avatar
Hey tech
Just a quick question, I have read that if you are a tooth or 2 out, your engine will have a drop in performance. Is this a quite noticeable difference, or would you have to be an expert to know the difference?
I changed my belt yesterday and I' just trying to make sure all is right (had a hell of a time lining up timing marks when putting on the belt).
Thanks.
Old Sep 26, 2008 | 06:39 PM
  #30
Depends on which way it is off. But usually you can feel a difference if it is off.
Old Jul 5, 2009 | 02:14 PM
  #31
stevepaa's Avatar
I can not see the pics. Why is that?
I am doing mine now and can not find the crankshaft marks.
Old Jul 5, 2009 | 03:09 PM
  #32
stevepaa's Avatar
so here are
1) right hand camshaft timing mark,
2) left hand camshaft timing mark from in front
3) left hand camshaft timing mark from above and it appaears to me that the left hand is off by one tooth.
4) the crankshaft and I can't see any marks
5) the tensioner is at ambient , 70 deg F, but appears to way to the left.
Attached Thumbnails  Crankshaft Timing Mark-rh-m.jpg    Crankshaft Timing Mark-lh-m.jpg    Crankshaft Timing Mark-img_1192.jpg    Crankshaft Timing Mark-cr-m-.jpg    Crankshaft Timing Mark-tens-.jpg
Old Jul 5, 2009 | 03:30 PM
  #33
bw77's Avatar
On my car, the "M"" is not the timing mark. Look for a barely visible single scribed line.
Old Jul 5, 2009 | 03:39 PM
  #34
stevepaa's Avatar
thanks, I found the crank mark and could never get it to align with the M marks.
Old Jul 5, 2009 | 05:00 PM
  #35
stevepaa's Avatar
okay. here is
1) r cam scribe front and top
2) left cam mark from top, it appears to be one tooth off
3) raised mark on crankshaft
4) what I believe to be the mark on engine, that little raised edge to the left?
5) tensioner is still way off
Attached Thumbnails  Crankshaft Timing Mark-r-cam-1.jpg    Crankshaft Timing Mark-r-cam.jpg    Crankshaft Timing Mark-l-cam2.jpg    Crankshaft Timing Mark-crank2.jpg    Crankshaft Timing Mark-crank.jpg
Old Jul 5, 2009 | 05:04 PM
  #36
stevepaa's Avatar
found this pic in another thread, where he was off 1 1/2 teeth
shows what I see as mark on crank and mark on engine
Old Jul 5, 2009 | 06:14 PM
  #37
stevepaa's Avatar
took the belt off and tensioner, did not remove crank pully
now I can see the crankmarks easier.
replaced water pump and will do belt idler pulley and tensioner now.
I expect to move exhaust canshaft back one tooth.
Old Jul 5, 2009 | 07:36 PM
  #38
stevepaa's Avatar
well i figured out that the timing marks on camshaft sprockets must line up with cutouts in the top cover. so they were right to begin with, but every time I tried it was off one so I moved the sprocket a little by hand
when I was moving the camshaft sprocket end they seem to be on some sort of eccentic.
Is there any way I could have messed that up moving the end around a little?
Old Jul 5, 2009 | 07:47 PM
  #39
The one with the VVT? It will be a little pressure on it.
Old Jul 5, 2009 | 07:54 PM
  #40
stevepaa's Avatar
VVT on both exhaust and intake
I had to move them slightly counter clockwise and then forward clockwise to find when they actually stated to push against the valves.
The exhaust required more movement. Is there any way to have screwed up the valve timing by moving these VVT sprockets by hand?
