dealer says throttle module replacement??
Old Aug 25, 2010 | 06:28 AM
spandxgrl's Avatar
Default dealer says throttle module replacement??
Here goes...
Check engine light came on about a month ago. Tried to have it checked at my local mechanic but no codes appeared when hooked up and the light just went off on its own. However, it came on and stayed on shortly thereafter. So I took it to the dealer to have the code read. They said the code that came up was showing that the throttle module would have to be replaced. I noted nothing abnormal about performance to them. Now a month later she is showing symptoms of hesitation and my cruise control works when she wants to (not sure if that is related). I really notice it at speeds between 55 and 70. The easiest way to describe it is that it feels like the brakes were tapped for a second.It's getting worse. The check engine light has not come back on again. 2 years ago she was idling funny and my local mechanic just removed the throttle cover and cleaned and all was good. But now he says that won't fix this.
Dealer estimate a month ago was $1050 to replace the throttle module. Augh! Help!
Is there any other fix than this? Could it be something else?
Thanks in advance!
Old Aug 25, 2010 | 08:44 PM
S80Mama's Avatar
Same issue with my car. The dealer quoted me $1107 to fix mine. I decided to go with the Xemodex rebuilt version which I hear is better than the Volvo ETM anyway for $599 ($50 for overnight shipping). My boyfriend and I are going to attempt replacing this ourselves as it doesn't appear to be too difficult of a repair. So add maybe $30 for the proper tools and that beats $1100 any day. If you're not comfy trying to fix it yourself, maybe you can find a shop that works on foreign cars to repair it for a couple hundred and supply the part to them. Good Luck!
pmrose
1998-2000 model year XC70
17
May 24, 2012 07:16 PM
osage
Apr 20, 2010 04:24 PM
rodmodder
Dec 12, 2007 11:11 PM
Rustynuts
Feb 19, 2007 10:23 PM
vicki
May 12, 2005 09:37 PM
