Depress clutch to start
Old 04-23-2018, 01:53 PM
SteveSkel's Avatar
Default Depress clutch to start
Hi
I’ve a 1999 petrol V70 2.5.
its had intermittent start problems sometimes taking 12 cranks to start.
Its has a new ignition coil, battery, distributor cap, leads and plugs to no effect.
Someone has told me that you need to have this car in neutral and the clutch depressed to start it. Is this correct?
Its going for diagnostics tomorrow.
Thanks
Steve
Old 04-24-2018, 09:02 AM
firebirdparts's Avatar
I am not sure when Volvo added a cranking safety switch. I have a 98 and it'll crank. Nothing is required on mine. But even if there was a clutch pedal safety switch on the 99, it would control cranking, so it would be incredibly obvious.
Old 04-24-2018, 11:18 AM
SteveSkel's Avatar
Thanks for that. It’s been for diagnostics and they can’t connect to the ECU, but it started every time for them.
Touch wood it’s also started every time for me with the clutch depressed.
maybe it’s a failing clutch sensor that has somehow allowed the car to start with clutch out but occasionally doesn’t like it?
Old 04-24-2018, 01:19 PM
According to eeuroparts.com, the Volvo clutch start switch 9472979 applies to 1999 - 2007 V70, but those are the 2.4L USA versions. So maybe you do have one.
Old 04-24-2018, 02:27 PM
SteveSkel's Avatar
Mine is the 2.5. I’m not sure whether that had one? Either way depressing the clutch seems to be working so far but time will tell
Old 04-24-2018, 02:34 PM
SteveSkel's Avatar
It’s a 2435 cc but says 2.5 on the back.
Old 04-29-2018, 07:56 AM
Blade's Avatar
I have a 2000 C70 (US model) with 5 speed, it doesn't have to be in neutral but I do need to press the clutch in order to start it.
suze
01-30-2014 07:42 AM
gentlejax2
06-18-2012 03:19 PM
shoebox92
03-23-2009 11:24 PM
Quick Reply: Depress clutch to start
