Door is Shut, but Chime will not go off???
Old Nov 18, 2011 | 01:53 PM
TrouperL's Avatar
Default Door is Shut, but Chime will not go off???
Might any of you have any comments, suggestion, etc., on my 1999 V70 GLT? When I shut the door, the chime/bell still goes off, as if the is open. Please help!!
Thanks, TrouperL
Old Nov 18, 2011 | 04:18 PM
tony1963's Avatar
The latch mechanism has the switch for the door light, chime, etc. all contained. Try spraying the door latch with silicone spray to wash out the dirty. Sometimes works. Otherwise, time for a new latch assy. Dealer item. I have replaced more than a few.
Old Nov 21, 2011 | 11:08 AM
TrouperL's Avatar
Thanks Tony, I will try that spray fix, first. Failing that...do you have any tips on getting the switch out, or instaling a new one. Anything I should be aware of? Since you have done this before, your knowledge is most helpful.
TrouperL
admasters
Oct 2, 2022 07:20 AM
Dennis Tobin
Jun 18, 2011 03:11 AM
tennisguy
May 16, 2006 03:13 PM
yellow95
May 1, 2006 08:59 PM
