driver side window won't let up, HELP PLEASE!
Old May 2, 2008 | 12:56 PM
98T5's Avatar
Default driver side window won't let up, HELP PLEASE!
I have a 98' T5 Turbo Wagon and I pushed the button for the driver side window and smoke came from the switch. then the window would not go back up!!!
ANY INFO IS WORSHIPPED...HELP!!!
Old May 2, 2008 | 01:13 PM
98T5's Avatar
Default RE: driver side window won't let up, HELP PLEASE!
I found out it's the driver's side switchpack, but how can I get the window back up until then?
I got the part on order right now.
Old May 2, 2008 | 05:41 PM
You will have to remove the door panel and hot wire the motor to make it go up.
Old May 3, 2008 | 12:19 PM
98T5's Avatar
ok, I'm all ears. tell me how to hot wire it?
I got the door panel off and I'm looking at the motor. now what?
Old May 3, 2008 | 02:21 PM
Unplug the motor.
The connect wires to the plug.
Now the motor works on swapping the + and - for up and down.
Add power and ground one way and see which way it goes. If it is trying to go down swap and wires and it should go up.
Old May 3, 2008 | 05:13 PM
98T5's Avatar
hmmm...where will I get that power from? I don't want to use jumper cables from the battery. I have a small load battery starter/charger, would that work?
Old May 5, 2008 | 06:29 PM
Yes or even sometimes if you have a battery operated drill that the battery comes out of.
I have used one of those in a pinch.
herbeapuce
Feb 22, 2013 09:48 AM
mlabrut
Apr 13, 2012 09:49 AM
rjb44
Aug 27, 2010 05:12 AM
scottsc70
Apr 5, 2010 11:25 AM
Capo Cam
Dec 16, 2008 02:52 PM
