one of 2 Hood retainer won't let go unless..
Old Feb 21, 2013 | 07:57 PM
herbeapuce's Avatar
Default one of 2 Hood retainer won't let go unless..
HI
we have a older Volvo S70 1998,
if I pull on the release to lift the hood, it will only free one of the 2 hooks; the other hook will still be closed.
the only way I can free the hood is: the driver to pull the release, then another person to start lifting the hood, applying a bit of force up; the free side will rise a bit, then the driver pulling a second time on the release and then it will pup up the second hook...so it will only pup if there is a tiny bit of pulling force on that hook
How to fix this Please ? how to adjust those retainers ? if I look at them while the hood is up and play with the release, they seems to work just fine. I would try to adjust it but I don't want to make the problem worst.
also it's winter here, we have snow and ice... but it seems this is not the problem.
what do you think ?
thanks
stef
Old Feb 22, 2013 | 08:05 AM
chrispy960's Avatar
On my 960, at the bottom of the mechanisms is a slot to put a screwdriver in to adjust. Just a little bit is needed, if it's too loose afterwards, try turning the other way.
Old Feb 22, 2013 | 09:48 AM
herbeapuce's Avatar
thanks for your help chrispy960
this thread was helpfull also:
https://volvoforums.com/forum/volvo-...e-stuck-21528/
regards
stef
MDUBBSS70
May 28, 2014 09:02 PM
WilliamGWilliams
Dec 9, 2012 07:59 PM
mclark1966
Oct 8, 2012 04:42 PM
gilber33
Mar 16, 2011 12:54 AM
davesee1
Jan 31, 2011 07:20 AM
