engine sputters at stop light
I have a 1998 Volvo V70. Lately it has taken on a new quirk- when sitting at a stop light (with my foot and the brake and in drive) it sputters, almost stalls, then goes back to idle. This happens only occasionally and at random.
My thought was:
Bad gas
Fuel Filter
Fuel Pump
Crank Sensor
Anyone else experience this?
My thought was:
Bad gas
Fuel Filter
Fuel Pump
Crank Sensor
RE: engine sputters at stop light
The seafoam is only good for the valves not the throttle body.
You will have to remove the hose for the throttle body and spray some carb cleaner on a rag and wipe it out or remove the throttle body and spray it out.
Also remove the idle motor and clean with carb cleaner.
Then you can run the seafoam through the motor to clean the valves.
