Engine Stall with 1/4 tank of gas - 2002 V70 T5 2.3L
Car stalls with a ¼ tank of gas (every time), no lights, no codes, add gas starts right up. The car is not out of gas there is 3 to 4 gallons of gas in the tank because I can only put in 17 gallons of gas in the tank after a stall (21.1 gallon tank). I have replaced the fuel pump, fuel sending unit, and fuel filter? Ideas??? I need some help??? Dealer is worthless…
The fuel pump was replaced under recall and was checked again by the dealer because the car would stall with a ¼ tank. I replaced the sending unit thinking the dealer screwed it up then they replaced the pump and I pulled the pump out again to verify the hose going to the sending was not twisted and/or kinked. I’m at a loss…
shoebox92
03-23-2009 11:24 PM
