Car stall when giving too much gas
Old Mar 13, 2015 | 04:52 AM
Meekum's Avatar
Default Car stall when giving too much gas
Guys, I feel as though I have tried everything right now, the problem has been going on for roughly 4 months now. Here is the problem. When I am at a complete stop and I give the car too much gas the car stalls, however if I just give the car a little bit of gas, or let it coast then hit the gas the car moves just fine. Also, when accelerating on the highway the gears are not very smooth, like the car kicks when it shifts. There was a MAP flow sensor code which went away after replacing the MAP, as well as a cylinder 1 misfire code which is still there
Here is what I have done recently in the past 4 months: Full tune up, timing belt, plugs, wires, dist cap and rotor, PCV system replacement, transmission drain and fill, replacement map. Just ordered a coil replacement which I forgot to do.
Old Mar 13, 2015 | 09:48 AM
Meekum's Avatar
Default Transmission not working
For some reason the transmission is not longer working, making a loud screeching sound when first putting the car in park. None of the gears engage, cannot move the car at all. There is some leaking underneath the car so I'm going to pull the pan and inspect everything. Does anyone have any ideas?
Old Mar 14, 2015 | 06:12 PM
If one of the axles come out it will stop the car from moving. Have you checked the trans fluid?
Old Mar 25, 2015 | 05:39 PM
Meekum's Avatar
Default Update
I do have a diagnostic kit, giving me misfire on first cylinder code, nothing else. The car is a 96, I am currently waiting on my transmission pressure tester to post some pressures in different gears. The transmission fluid level is fine, first thing I checked.
remedemic
May 23, 2014 08:52 AM
1986volvo745
Jul 27, 2010 05:07 PM
aryanvahedi
Nov 18, 2009 08:59 PM
jwandhistools
Aug 11, 2009 09:43 AM
fundunski
May 25, 2008 01:47 AM
