Fautly In Dash Exterior Temp Gauge Readings
Old May 26, 2009 | 03:49 PM
grosseile88's Avatar
Default Fautly In Dash Exterior Temp Gauge Readings
I have a 2001 V70 T5 that gets faulty exterior temperature gauge readings from the in dash reading from time to time. Sometimes it is dead on, others it is 20 plus degrees off (typically colder) what the acutal outside temp actually is. Wondering if there is there some sensor that needs to be replaced or cleaned or is it even worth the cost or hassle??
Thanks!!
Old May 26, 2009 | 07:14 PM
The sensor is in the passenger side outside mirror.
Old Aug 30, 2009 | 04:41 PM
1mochi's Avatar
There are sensors on both mirrors. Before you replace it, try cleaning the sensor. You will need to remove the mirror to pry off the sensor.
This fixed my misreads.
roosterstoker
Mar 5, 2016 08:20 AM
AnEskimo
Mar 7, 2014 08:29 PM
blackbrick
May 7, 2011 01:46 PM
vcolper
Nov 1, 2006 10:20 PM
