Filter on A/C?
On the 98 open your hood look at the pass side you will see some t25 torx screws holding down the cowl which is the plastic cover under your windshield wipers. Remove 3 of the screws on pass side and the clamp holding the drain to it pull up on cowl and you will see the cabin filter there. pull it out and remove it from the insert and reinstall a new filter in it then reinstall into car.
ORIGINAL: b5254t
It is the cabin filter and it is up under the cowl on pass side on 98-00 v70 and under the pass side glovebox area on 01- models.
I think this is it at Autozone: http://www.autozone.com/R,APP968741/...ductDetail.htm
