flame trap/rattle test?
Also depending on the year. The 1998 has the flame sheild in the induction hose just before the throttle body.
The newer cars don't have a flame sheild. Most just have a Bango fitting on the bottom of the intake that the small hose clogs on causing excess pressure. But I have also seen the vent box clogged up fully alot of times.
The cap test might or might not work. If it is clogged with it running you can pull the dipstick and hear it release.
Sometimes you need to give it a little gas first then pull the dipstick.
