Fuel door bracket
Fuel door bracket
I have three issues with my new wagon that I hope someone has advice for me:
- The fuel door came off. The bracket mechanism is less than $10.00. The picture does not make clear how it mounts. Does it just snap into the four holes in the body panel?
- There is a mid range whining upon start up that goes away after less than a minute. What is it fan belt or blower motor? how can I stop the whining?
- The self cancelling indicators do not readily self cancel. You have to yank the wheel over a little. How can fix this.
Welcome to VolvoForums.com.
Fuel door comes with attached push rivits. Easy to install. Put in place and push in the extended tabs.
Whinning is likely the cold start air pump. You can check your VIN to see if it has one but if you do a search you'll likely see pics of it. Not suppose to stop until it turns off.
Turn signal bumps suck on these FWD cars. Not sure if there is a fix for it but it is set to close to tdc.
rolling2
2001-2013 model year XC70
05-05-2015 01:44 AM
